Adding a Wire Port to the Monopole
Define a wire port on the monopole. A voltage source will be added to this port.
Select the monopole.
- In the model tree, select Line1.
- In the details tree, select Wire1.
Tip: Wire1 is the wire element associated with Line1.
Define the wire port on the selected wire (monopole) using one of the following
workflows:
- On the Source/Load tab, in the
Ports group, click the
Wire port icon.
- On the details tree, a right-click context menu is available. Select Create port > Wire port.
Use the default port settings.
- Click Create to create the port and close the dialog.
