Defining a Wire Port for the Transmission Line
Define a wire port for the transmission line.
Select the vertical wire in the 3D view located farthest
away from the monopole.
The wire element associated with the selected wire is highlighted in the details tree.
On the details tree, a right-click context menu is
available on the wire element. Click Create port > Wire port.
View the port preview in the 3D view to ensure the correct
edge is selected.
The port is indicated by a sphere with a green centre.
- Use the default settings for the port.
- Create Create to create the port and close the dialog.
