Adding Ports, Sources and Loads
Create two wire ports for the monopole and transmission line, excite the monopole with a voltage source and add a load to the transmission line.
Note: Voltage sources and discrete loads are applied to ports and not directly to the model geometry or mesh. A port must be defined before a source or load can be added to the model.
