Example Overview
Consider the coupling between a monopole antenna and a loaded transmission line above a ground plane.
Create the monopole antenna using a line and the loaded transmission line using a polyline. The ground plane is modelled using an infinite ground plane.
Figure 1. The monopole antenna and the loaded transmission line above an infinite ground plane.
