Perform network analysis for a WiMAX air interface in a rural/suburban scenario for fixed communications, such as
“the last mile” to a residential internet subscriber.
WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications
ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning
to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output
(MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine
the actual antenna pattern while taking into consideration the local environment.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models
as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks,
ICNIRP and EM compliance.
Indoor Communication, 3G
The network planning of an indoor scenario is investigated. The model consists of a large multi-story building.
Urban Communication, 3G
The network planning of an urban scenario is investigated. The geometry is described by extruded polygons that represent urban buildings.
Indoor Communication, 802.11g
Calculate network planning for 802.11g using three different methods inside a large building.
Urban Communication, 802.11g
Calculate network planning for 802.11g using three different methods in an urban scenario.
Indoor UWB Using IRT
Perform network analysis for ultra-wide band (UWB) frequencies in an indoor scenario.
WiMAX, Indoor
Perform network analysis for indoor WiMAX coverage.
WiMAX, Rural, Fixed
Perform network analysis for a WiMAX air interface in a rural/suburban scenario for fixed communications, such as “the last mile” to a residential internet subscriber.
WiMAX, Urban, Fixed
Perform network planning for fixed WiMAX coverage in an urban scenario.
WiMAX, Urban, Mobile
Perform network planning for mobile WiMAX coverage in an urban scenario.
LoRaWAN and IoT
Perform network planning for the internet of things (IoT) in an urban scenario.
