MV-7009: Remote Co-simulation with Simulink
In this tutorial, you will learn how to use the MotionSolve-Simulink remote co-simulation interface, driving the model from Simulink via an S-Function.
MotionSolve allows you to co-simulate with Simulink when the two software are remotely located, through an implementation of the Inter Process Communication (IPC) approach via sockets.
Software and Hardware Requirements
- MotionSolve
- MATLAB/Simulink (MATLAB Version R2015a, Simulink Version 8.5) (or newer)
- PC with 64bit CPU, running Windows 7/10 and/or
- Linux RHEL 6.6 or CentOS 7.2 64
Simulation Environment
In this tutorial, it is assumed that MATLAB is installed on Machine "A" and MotionSolve is installed on Machine "B". The following scenarios are feasible:
| Machine "A" | Machine "B" | IPC Co-simulation possible? |
| MATLAB/Simulink, Windows 64-bit | MotionSolve, Windows 64-bit | Yes |
| MATLAB/Simulink, Windows 64-bit | MotionSolve, Linux 64-bit | Yes |
| MATLAB/Simulink, Linux 64-bit | MotionSolve, Windows 64-bit | Yes |
| MATLAB/Simulink, Linux 64-bit | MotionSolve, Linux 64-bit | Yes |
| MATLAB/Simulink, Windows 64-bit (Requires a Windows 64-bit MotionSolve installation) | MotionSolve, Windows 64-bit | Yes |
| MATLAB/Simulink, Windows 64-bit (Requires a Windows 64-bit MotionSolve installation) | MotionSolve, Linux 64-bit | Yes |
| MATLAB/Simulink, Linux 64-bit (Requires a Linux 64-bit MotionSolve installation) | MotionSolve, Windows 64-bit | Yes |
| MATLAB/Simulink, Linux 64-bit (Requires a Linux 64-bit MotionSolve installation) | MotionSolve, Linux 64-bit | Yes |
Figure 1. Co-Simulation Environment Used for this Tutorial
Inverted Pendulum Controller
Consider an inverted pendulum, mounted on a cart. The pendulum is constrained at its base to the cart by a revolute joint. The cart is free to translate along the X direction only. The pendulum is given an initial rotational velocity causing it to rotate about the base.
Figure 2. Inverted Pendulum Model Setup
Figure 3. Block Diagram Representation of the Controller
- is the angular displacement of the pendulum from its model configuration
- ω is the angular velocity of the pendulum about its center of gravity as measured in the ground frame of reference
- x is the translational displacement of the cart measured from its model configuration in the ground frame of reference
- is the translational velocity of the cart measured in the ground frame of reference
- is a reference signal for the pendulum's angular displacement
- is a reference signal for the pendulum's angular velocity
- is a reference signal for the cart's translational displacement
- is a reference signal for the cart's translational velocity
A disturbance is added to the computed control force to assess the system response. The controller force acts on the cart body to control the displacement and velocity profiles of the cart mass.
- Solve the baseline model in MotionSolve only (that is, without co-simulation) by using the inverted pendulum model with a continuous controller modeled by a Force_Vector_OneBody element. You can use these results to compare to an equivalent co-simulation in the next steps.
- Review a modified MotionSolve inverted pendulum model that mainly adds the Control_PlantInput and Control_PlantOutput entities that allow this model to act as a plant for Simulink co-simulation.
- Review the controller in Simulink.
- Perform a co-simulation and compare the results between the standalone MotionSolve model and the co-simulation model.
Before you begin, copy all the files in the <altair>\tutorials\mv_hv_hg\mbd_modeling\motionsolve\cosimulation folder to your working directory (referenced as <working directory> in the tutorial). Here, <altair> is the full path to the product installation.
Run the Baseline MotionSolve Model
In this step, use a single body vector force (Force_Vector_OneBody) to model the control force in MotionSolve. The force on the cart is calculated as:
, where
is the disturbance force,
is the control force,
are gains applied to each of the error signals
is the error (difference between reference and actual values) on the input signals.
The angular displacement and velocity of the pendulum are obtained by using the AY() and WY() expressions respectively. The translational displacement and velocity of the cart are obtained similarly, by using the DX() and VX() expressions.
Define the Plant in the Control Scheme
A MotionSolve model needs a mechanism to specify the input and output connections to the Simulink model. The MotionSolve model (XML) used above is modified to include the Control_PlantInput and Control_PlantOutput model elements and provide these connections. In this tutorial, this has already been done for you, and you can see this by opening the model InvertedPendulum_Cosimulation.mdl from your <Working_Directory>.
This model contains two additional modeling components:
| Component Name | Component Type | Description |
| Plant Input Simulink | Plant input | This Control_PlantInput element is used to define the inputs to the MotionSolve model |
| Plant Output Simulink | Plant output | This Control_PlantOutput element is used to define the outputs from the MotionSolve model |
- The Control_PlantInput element defines the inputs to a mechanical system or
plant. For this model, only one input is defined in the "Plant Input Simulink"
solver array. This is set to the ID of the solver variable that holds the
control force from Simulink.
Figure 5. The Definition of the Input Channel to MotionSolve - The Control_PlantOutput element defines the outputs from a mechanical system
or plant. For this model, four outputs are defined in the "Plant Output
Simulink" solver array. These are the pendulum rotation angle, the pendulum
angular velocity, slider displacement and slider velocity.
Figure 6. The Definition of the Output Channels from MotionSolveThe inputs specified using the Control_PlantInput and Control_PlantOutput elements can be accessed using the PINVAL() and POUVAL() functions, respectively. Since the Control_PlantInput and Control_PlantOutput list the ids of solver variables, these inputs and output variables may also be accessed using the VARVAL() function. For more details, please refer to the MotionSolve User's Guide on-line help.
This model has the following connections:- Plant Input: A single control force that will be applied to the cart.
- Plant Output: The pendulum's angular displacement and angular velocity; the cart's translational displacement and velocity.
Set Up Environment Variables
- Control Panel (Windows)
- In the shell/command window that calls MATLAB (with the set command on Windows, or the setenv command on Linux)
- Within MATLAB, via the setenv() command
An example of the usage of these commands is listed below:
| Environment variable | Value | Windows shell | Linux shell | MATLAB shell |
| PATH | \mypath | set PATH=\mypath | setenv PATH \mypath | setenv('PATH','\mypath') |
Set Up the Co-simulation
The core feature in Simulink that creates the co-simulation is an S-Function (System Function) block in Simulink. This block requires an S-Function library (a dynamically loaded library) to define its behavior. MotionSolve provides this library, but the S-Function needs to be able to find it. To help MATLAB/Simulink find the S-Function, you need to add the location of the S-Function to the list of paths that MATLAB/Simulink uses in order to search for libraries.
The S-Function libraries for co-simulation with MotionSolve is called mscosimipc – for Inter Process Communication (IPC) using TCP/IP sockets for communication.
This file is located at <altair>\hwsolvers\motionsolve\bin\<platform>.
The location of this file needs to be added to the search path of MATLAB for the S-Function to use mscosimipc.
This can be done in one of the following ways:
Use the menu options.
Use MATLAB commands.
View the Controller Modeled in Simulink
Perform the Co-simulation
Compare the MotionSolve-only Results to the Co-simulation Results
Appendix
- Option 1: Fully install MotionSolve on Machine A, just like Machine B
- Option 2: Install a partial set of libraries on Machine A
If you exercise Option 2 above, then the list of files that need to be copied/installed on the machine where Simulink is located include the following:
| Windows | Linux Path |
| mscosimipc.mexw64 | mscosimipc.mexa64 |
| msdaemon.exe | msdaemon |
| nuclient.dll | nuclient.so |
| pthreadVC2.dll |
| Environment Variable | Windows Path | Linux Path |
| NUSOL_DLL_DIR | ..\motionsolve\remote_cosimfiles\ | ../motionsolve/remote_cosimfiles |
| PATH | ..\motionsolve\remote_cosimfiles\;%PATH% | ../motionsolve/remote_cosimfiles:$PATH |
| LD_LIBRARY_PATH | - | ../motionsolve/remote_cosimfiles: $LD_LIBRARY_PATH |
| MS_SERVER_IP_ADDRESS | IP address of Machine “B” | IP address of Machine “B” |
