Split 1D Elements
Use the Split 1D Elements tool to split a 1D element keeping proper section distribution along the newly generated elements when the original beam property has a tapered section.
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
Create an assembly structure from a .csv file definition.
These tools enable the creation of 1D elements from surface lines, organizing them into components. They also offset/orient these elements based on the attached shell elements and calculating properties of these 1D elements from 3D solid or shell FE element sections.
Evaluate sectional properties from a section cut on both 1D and 2D elements.
Review the beam's neutral axis position and plot MoI and flexural stiffnesses.
Calculate beam properties from a solid or FE model.
Beam/bar orientation can be defined by specifying a node (internally the solver calculates the vector).
