Create Material Inputs
Use the Materials tool to create design variables based on material options for selected properties.
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
An exploration is a multi-run simulation. Each exploration includes input design variables, and output responses. Explorations may also include goals, consisting of an objective and constraints.
An input design variable is a system parameter that influences the system performance in the chosen output response. Typical design variables may be a part's thickness, shape, or material property. Ranges, with lower and upper bounds, are specified and the variable's value will vary within the exploration. The terms input, input design variable, and design variable are used interchangeably.
Use the Gauge tool to create design variables based on the thickness of selected properties.
Use the Size tool to create size design variables based on the attributes of selected entities.
Use the Shape tool to create shape design variables based on selected shapes.
Use the Connectors tool to create design variables based on selected connectors.
Use the Parameters tool to create size design variables by converting existing parameters.
Edit design variable properties and preview thickness and shape type inputs.
Design variables can be linked to one another to ensure that their values remain the same throughout the exploration. This is useful in cases of symmetry or when it is known, for example, that two parts will have the same thickness. In addition, reducing the number of independent variables will reduce the number of runs required for the exploration.
An output response is a measurement of system performances, such as mass, volume, displacement, stress, strain, or reaction forces.
Objectives are metrics to be minimized or maximized in an optimization exploration. Minimizing mass to find a lightweight design is a common example.
Constraints need to be satisfied for an optimization to be acceptable. Constraints may also be associated with a DOE. While not used in the evaluation of the DOE, constraints can be useful while visualizing DOE results. Limits on displacement or stress are common examples.
Review the explorations, inputs, responses, and goals in your design setup.
Use the Evaluate tools to run the exploration and review reports.
View tutorials for Design Explorer workflows.
