View new features for HyperWorks 2021.1.
Explore the HyperWorks user interface.
The title bar displays the name of the file that is currently opened, along with the active product and user profile.
The main display area of the user interface is called a page. Each page can contain up to 16 windows.
The ribbon allows you to quickly access tools and standard functions, and is located along the top of HyperWorks. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
Browsers supply a great deal of view-related functionality in HyperWorks by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
The modeling window is where your model is displayed.
The status bar displays information pertaining to the currently loaded model, active tools and panels, current collectors, and snap filter options.
Context menus are floating menus that are accessed by right-clicking on elements in the user interface. They provides immediate access to a short list of commands that are contextually relevant to the selection.
Guide bars guide you through a series of commands, required inputs, and options necessary to complete a workflow that is specific to a tool.
The Tcl Console enables you to enter and execute Tcl/Tk commands instead of using the user interface.
Overview of the HyperView commands that can be entered in the Tcl Console to manipulate the model.
CurveEditor class, its member functions, and their use-cases are described here.
Creates a curveEditor object.
Creates the curve on the given plot's page.
Captures the screen of the external window and saves it to a user-defined file.
Erases the content in the plot window.
Erases the curve in the plot page area.
Scales the x axis and/or the y axis to fit with the curve displayed.
Returns entity specific properties.
Gets number of curves
Gets value associated with the corresponding metadata.
Returns the plot type.
Changes the curve and axes' properties.
Adds metadata on curve based on the given index.
Sets the plot type for curve editor.
Shows or hides the legend. Value can be displayed on top of each bar for bar charts only.
The Intellisense window allows you to quickly locate commands for a given handle, as well as their parameters.
The HWC Console, with the command line, supports auto-completion and interactive help and allows easy modification and re-execution of commands.
The Message Log lists the actions performed in the current session. The dialog also provides you with information about your file (warnings, errors, and so on).
Command files can be used to create new command scripts that perform automation, or to recover previously performed steps.
Certain parts of the user interface, such as browsers, toolbars, and panels, can be undocked and repositioned as needed.
View controls enable you to control the view and display of your model in the modeling window.
Quickly find and open the tools, panels, and browsers that are available from the ribbons or from the Utility Browser, as well as create entities and solver cards.
Select and deselect entities to modify with other HyperWorks tools. Selected entities are outlined to indicate their selection state.
Translate, rotate, and align the model.
Use the Measure tool to measure length, angles, radii, areas, volumes, centers of gravity, and bounding boxes.
Learn how to manipulate entities in HyperWorks.
Undo and redo actions performed in HyperWorks.
Default keyboard shortcuts and mouse controls.
HyperMesh composites modelings.
ON THIS PAGE
ON THIS PAGE
