Export Optimization Deck
Export of optimization solver deck.
Using the Export Optimization Deck panel, you can export the solver deck and also perform Fourier Transformation if required.
Figure 1. Export Solver Deck Options
- Windowing Type
- A typical modal transient run is a time based analysis. For optimizing the E-line for systematic or a non-systematic optimization problem in the frequency domain, we need to convert the time domain data in the input deck to the frequency domain.
- Number of Blocks
- Perform a block based FFT where the signal is processed by breaking it into given no of blocks and suitable windowing technique is used to reduce the effects of the leakage.
- Overlap (%)
- Overlap percentage is also a measure to reduce the truncation effects.
