poIPost ExportResultDefinitions
Exports the result definitions to an XML file.
post_handle ExportResultDefinitions filename
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, exports the result definitions to an XML file.
filename
The name of the XML to which the definitions will be exported.
To export current result definitions to result_defs.xml:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client ExportResultDefinitions result_defs.xml
hwi CloseStack
Returns error code and sets error condition on the session handle. See session_handle GetError.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
