poIPost AddResult
Adds a result definition with the given label.
post_handle AddResult label context notify
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, adds a result definition with the given label. It also returns the ID of the created result definition.
label
The result definition label.
context
A string indicating the context of the result ID (scalar, tensor, vector, iso).
notify
Set to 'true' to trigger an event to update the browser, otherwise 'false'. The default value is true.
To add a new scalar result with label R1:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client AddResult R1 scalar true
hwi CloseStack
Returns 0 if there was an error adding the result and sets an error condition on the session handle. See session_handle GetError.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
