poICollisionSet SetEnableProximity
Sets the proximity state.
poICollisionSet_handle SetEnableProximity
HyperView Tcl Modify
This command sets the proximity state.
Error
Returns 0 if successful, otherwise an error code.
View new features for HyperWorks Desktop 2021.1.
Adds selected entities to be used by the collision control.
Returns the event which triggers animation stop.
Returns the binding: part, element, or node.
Returns the proximity state.
Returns the collision set ID.
Returns the collision set label.
Returns the proximity value.
Returns a selection list for a given group.
Removes the selected entities.
Clears all selection sets.
Sets the event which triggers animation stop.
Sets the binding: part, element, or node.
Sets the collision set label.
Sets the proximity value.
