poICollisionSet GetID
Returns the collision set ID.
poICollisionSet_handle GetID
HyperView Tcl Query
This command returns the collision set ID.
Error
Returns the collision set ID, or null_ID (0) if an error occurred.
View new features for HyperWorks Desktop 2021.1.
Adds selected entities to be used by the collision control.
Returns the event which triggers animation stop.
Returns the binding: part, element, or node.
Returns the proximity state.
Returns the collision set label.
Returns the proximity value.
Returns a selection list for a given group.
Removes the selected entities.
Clears all selection sets.
Sets the event which triggers animation stop.
Sets the binding: part, element, or node.
Sets the proximity state.
Sets the collision set label.
Sets the proximity value.
HyperView Tcl Query
