amfIMarker SetName
Sets the name of the marker.
marker_handle SetName name
- name
- Sets the name of the marker.
marker_handle SetName “New Marker Name”
Error
- 1 = HW_Error
- 3 = HW_InvalidHandle
- 4 = HW_InvalidArgs
View new features for HyperWorks Desktop 2021.1.
Gets the value of the flag denoting whether the marker symbol should be displayed as a filled circle or as an outline.
Gets the index of the final frame for which the marker is being tracked.
Returns a font handle.
Gets the index of the initial frame for which the marker is being tracked.
Gets the color of the marker symbol.
Gets the name of the marker.
Gets the value of the flag denoting whether or not the marker should have its tracking data recalculated.
Gets the value of the flag denoting whether or not the marker and its trace should be drawn on the video.
Gets the color of the trace line drawn for a marker.
Gets the thickness of the trace line drawn for a marker.
Gets the initial X coordinate of the marker, in pixels.
Gets the initial Y coordinate of the marker, in pixels.
Sets the value of the flag denoting whether the marker symbol should be displayed as a filled circle or as an outline.
Sets the index of the final frame for which the marker will be tracked.
Sets the index of the initial frame for which the marker will be tracked.
Sets the color of the marker symbol.
Sets the value of the flag denoting whether or not the marker should have its tracking data recalculated.
Sets the value of the flag denoting whether or not the marker and its trace will be drawn on the video.
Sets the color of the trace line drawn for a marker.
Sets the thickness of the trace line drawn for a marker.
Sets the initial X and Y coordinates of the marker, in pixels.
