report::item
Report Item to access and modify Report Items.
set item [::rpti::item getinterface -name
new_report_session1]report:item apply
For better performance the data created, manipulated or deleted, will go into a cache.
- Syntax
$item apply
- Parameters
- -name
- Value: Layout name to use in case of presentation.
- -item list
- Value: List of item ids to apply.
- -parent
- Value: parent of the cached items. If not specified root item will act as a parent.
- Returns
- 1 for OK, .tcl-error in case of error.
report::item clone
Clone an Item.
- Syntax
$item clone
- Parameters
- -id
- Value: Item ID
- Returns
- New item ID.
report::item createchapter
Creates an item of type "chapter".
- Supported Property Names
-name -value -parent -type (read only)
- Syntax
$item createchapter
- Returns
- The ID of the item or .tcl-error in case an error occurred during creation, that is, $item_i createchapter -name "My Chapter Item".
report::item createimage
Creates an item of type image.
-name -value -parent -type (read only) -config -hwpage -hwwindow
- Syntax
$item createimage
- Returns
- The ID of the item or .tcl-error in case an error occurred during creation.
report::item createslide
Creates an item of type slide. This item type is valid only for presentation reports.
-name -value -parent -type (read only) -layoutname or -index-layoutname -> name of the layout-index -> slideindex starts from 1
- Syntax
$item createslide
- Returns
report::item createtable
Creates an item of type table.
-name -value -parent -type (read only) -numberofrows -numberofcolumns -showcolumnheader -showrowheader
- Syntax
$item createtable
- Returns
report::item createtext
Creates an item of type text.
- Syntax
$item createtext
- Returns
report::item createbreak
Creates an item of type break.
- Syntax
$item createbreak
- Returns
report::item createtextdocument
Create items of type textdocument.
-name -file -parent
- Syntax
$item createtextdocument
- Returns
report::item createworddocument
Create items of type worddocument.
-name -file -parent
- Syntax
$item createworddocument
- Returns
report::item createexceldocument
Create items of type exceldocument.
-name -value -parent -type (read only) -file -sheet -caption -caption_location
- Syntax
$item createexceldocument
- Returns
report::item createtableofreference
Create items of type tableofreference.
- Syntax
$item createtableofreference
- Returns
report::item createexternalobject
Create items of type externalobject.
-name -file -parent
- Syntax
$item createexternalobject
- Returns
report::item delete
Deletes the item with the specified ID.
- Syntax
$item delete
- Parameters
- -id
- Value: Item ID
- Returns
report::item get
Queries the value of one property or role or attribute.
- Syntax
$item get
- Parameters
- -id
- Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
- For
- Value: Use
rpti::item getpropertykeylistfor list of dynamic properties.
- Returns
- The value of the specified property/role/attribute or .tcl-error in case of error.
- Example
ardi::item get -id $id -property parent
report::item getattribute
Get item attribute.
- Syntax
$item getattribute
- Parameters
- -id
- Value: Item ID
- -name
- Value: Attribute Name
- Returns
- Attribute value.
report::item getmasterlayouts
Queries master layouts.
- Syntax
$item getmasterlayouts
- Returns
- The list of master layout ID's.
report::item getpropertyid
Queries ID of property.
- Syntax
$item getpropertyid
- Parameters
- -id
- Value: Item ID
- -key
- Value: Property key
report::item getpropertykeylist
Queries list of properties.
- Syntax
$item getpropertykeylist
- Parameters
- -id
- Value: Item ID
- Returns
- List of property keys for a particular item ID.
report::item getrole
Get item role.
- Syntax
$item getrole
- Parameters
- -id
- Value: Item ID
- -name
- Value: Role Name
- Returns
- Role value.
report::item getroot
Queries the ID of the report root item. This is the top most item.
- Syntax
$item getroot
- Returns
- The ID of the report root item.
report::item getselection
Queries current selected item.
- Syntax
$item getselection
- Returns
- Selected item ID.
report::item getslidelayouts
Queries slide based layouts.
- Syntax
$item getslidelayouts
- Returns
- The list of slide layout ID's.
report::item gettype
Queries the type of the item with the specified ID.
- Syntax
$item gettype
- Parameters
- -id
- Value: Item ID
- Returns
- The type of the item.
report::item gettypelist
Queries available types of items.
- Syntax
$item gettypelist
- Returns
- A list of item types.
report::item hasattribute
Check if an item attribute exists.
- Syntax
$item hasattribute
- Parameters
- -id
- Value: Item ID
- -name
- Value: Attribute name
- Returns
- 1 if role exists, 0 if role does not exist.
report::item hasproperty
Check if the item has property with specified key.
- Syntax
$item hasproperty
- Parameters
- -id
- Value: Item ID
- -key
- Value: Property key.
- Returns
- 1 if valid , 0 if invalid.
report::item hasrole
Check if an item role exists.
- Syntax
$item hasrole
- Parameters
- -id
- Value: Item ID
- -name
- Value: Role name.
- Returns
report::item insert
Insert an item to a parent.
- Syntax
$item insert
- Parameters
- -id
- Value: Item ID to insert.
\parent -parent parentitemid: parent item id
- -index
- Value: Index in parent
- Returns
- 1 if success, error message if failed.
report::item isleaf
Check if the item is a leaf.
- Syntax
$item isleaf
- Parameters
- -id
- Value: Item ID
- Returns
- 1 if valid, 0 if invalid.
report::item isvalid
Check if the item with the specified ID is valid.
- Syntax
$item isvalid
- Parameters
- -id
- Value: Item ID
- Returns
report::item loadproperty
Load items properties defined in configuration .xml.
- Syntax
$item loadproperty
- Parameters
- -id
- Value: Item ID
- Returns
report::item redraw
Notifies all registered views to redraw itself.
- Syntax
$item redraw
report::item remove
Remove an item from parent.
- Syntax
$item remove
- Parameters
- -id
- Value: Item ID to remove.
- Returns
report::item removerole
Remove item role if exists.
- Syntax
$item removerole
- Parameters
- -id
- Value: Item ID
- -name
- Value: Role name.
report::item reparent
Re parents an object that already has a parent.
- Syntax
$item reparent
- Parameters
- -id
- Value: Item ID to reparent.
\parent -newparent parentitemid: New parent item id
- -index
- Returns
report::item set
Sets one or multiple parameters to specified values.
- Syntax
$item set
- Parameters
- -id
- For
- Value: A full list of standard property names see Supported
property names above. Use
- Returns
- Example
$item set -id $id -name "My Text Item" -value "Good monring, how are you today?"
report::item setattribute
Sets/update item attribute.
- Syntax
$item setattribute
- Parameters
- -id
- Value: Item ID
- -name
- Value: Attribute Name usually a string
- -value
- Value: Attribute Value
- Returns
report::item setrole
Set/update item role
- Syntax
$item setrole
- Parameters
- -id
- Value: Item ID
- -name
- Rolename: Role Name usually a string
- -value
- Rolevalue: Role Value
- Returns
report::item setselection
Queries current selected item set using rpti::item setselection.
- Syntax
$item setselection
- Parameters
- None.
- Returns
- Selected item ID.
report::item validate
Evaluates registered validate callback.
- Syntax
$item validate
- Parameters
- -id
- Itemid: Item ID.
- Returns
- -1 if errors, 0 if warnings and 1 if passed.
