report::frwk
The Report Framework enables you to execute and export the report.
::rpti::frwk start -name new_report_session1 set
frwk [::rpti::item getinterface -name new_report_session1]report::frwk addcustompackage
Registers .tcl package to load containing custom module.
- Syntax
$frwk addcustompackage
- Parameters
- -directory
- Value: Directory that contains .tcl package
- -packagename
- Value: Name of .tcl package.
- Returns
- 1 for ok; .tcl-error in case of error.
report::frwk addcustompath
- Syntax
$frwk addcustompath
- Parameters
- -directory
- -packagename
- Returns
- 1 for OK; .tcl-error in case of error.
report::frwk appendtemplate
Appends the specified report template to existing report template.
- Syntax
$frwk appendtemplate
- Parameters
- -file
- Value: File name of report template.
- Returns
- 1 for OK, .tcl-error in case of error
report::frwk execute
Executes the current report template.
- Syntax
$frwk execute
- Parameters
- -id
- Value: ID of the items to be executed.
- Returns
- 1 for OK
report::frwk export
Exports the Ms-office report based on current report template.
- Syntax
$frwk export
- Parameters
- -file
- Value: File name of Ms-office report including extension.
- Returns
- 1 for OK, .tcl-error in case of error.
report::frwk exportas
Exports Office document as specified format.
- Syntax
$frwk exportas
- Parameters
- -file
- -format
- Value: PDF, ODT/OD & HTM.
- Returns
report::frwk geterrorcount
Get number of errors.
- Syntax
$frwk geterrorcount
- Parameters
- None.
report::frwk getexportitems
Get number of items marked for export.
- Syntax
$frwk getexportitems
- Parameters
- None.
report::frwk::getmasterdocument
Queries the current Ms-office master template file based on current report format (document, presentation).
- Syntax
$frwk getmasterdocument
- Returns
- The current Ms-office master template file.
report::frwk getreporttype
Queries the Ms-office report type.
- Syntax
$frwk getreporttype
- Returns
- The current Ms-office report type (word, ppt).
report::frwk getsyncitems
Get number of items marked for sync.
- Syntax
$frwk getsyncitems
- Parameters
- None.
report::frwk getunexecuteditems
Get number of not executed items.
- Syntax
$frwk getunexecuteditems
- Parameters
- None.
report::frwk getworkdir
Queries the current work directory.
- Syntax
$frwk getworkdir
- Parameters
- None.
- Returns
- The current work directory.
report::frwk ispaused
Check if report execution is paused.
- Syntax
$frwk ispaused
report::frwk isrunning
Check if report execution is running.
- Syntax
$frwk running
report::frwk isstarted
Check if report execution is started.
- Syntax
$frwk isstarted
report::frwk loadtemplate
Loads the specified report template.
- Syntax
$frwk loadtemplate
- Parameters
- -file
- -filelist
- Value (optional): list of file names as seen on Report Template dialog or as passed or as used in the order of running HyperWorks in batch mode. See HyperWorks documentation "barchmode" parameter "-tplParams"
- Returns
- 1 for OK, Tcl-error in case of error.
report::frwk newreport
Creates new report template.
- Syntax
$frwk newreport
- Parameters
- -type
- Value: Type of report (word, ppt).
- Returns
report::frwk quit
Quits ARD.
- Syntax
$frwk quit
- Parameters
- -mode
- Value: Interactive (interactive with GUI) mute (engine only, no GUI).
- Returns
report::frwk redraw
Notifies all registered views to redraw itself.
- Syntax
$frwk redraw
report::frwk registertype
Register a new type relating to an editor.
- Syntax
$frwk registertype
- Parameters
- -type
- Value: Unique one-word, all lowercase identifier for the new type. This is the identifier you will need to specify in the module's .xml file.
- -class
- Value: ITcl class that contains the editor code. Make sure to use proper name space for your custom editor to avoid naming clashes.
- Returns
report::frwk savetemplate
Saves the current report template.
- Syntax
$frwk savetemplate
- Parameters
- -file
- Returns
report::frwk setmasterdocument
Sets the Ms-office master template based on current report format (document, presentation).
- Syntax
$frwk setmasterdocument
- Parameters
- -file
- Value: Ms-office master template file.
- Returns
report::frwk setworkdir
Sets the work directory to specified path.
- Syntax
$frwk setworkdir
- Parameters
- -directory
- Value: Path of work directory.
- Returns
report::frwk startexec
Flags execution start.
$frwk startexec
report::frwk stop
Flags stop execution.
- Syntax
report::frwk stop
report::frwk sync
Syncs the Ms-office report based on current report structure.
- Syntax
$frwk sync
- Parameters
- -file
- Returns
report::frwk templateloadpostcommand
Specify the callback to be called after a new report template got loaded.
- Syntax
$frwk templateloadpostcommand
- Parameters
- -command
- Value: Command, Tcl procedure or ITcl method to be called.
- Returns
report::frwk templateloadprecommand
Specify the callback to be called before a new report template is being loaded.
- Syntax
$frwk templateloadprecommand
- Parameters
- -command
- Returns
report::frwk validate
Validate an item.
- Syntax
$frwk validate
- Parameters
- -id
- Value: Specify item ID to validate.
