Probes
The data for a voltage probe, current probe or a SPICE probe can be added to a graph.
On the Home tab, in the
Add results group, click the Probes icon.
- Voltage
- Current
Use POSTFEKO to validate meshed geometry and analyse and post-process results.
View the main elements and terminology in the POSTFEKO graphical user interface (GUI).
POSTFEKO has various default settings that you can configure to customise it to your preference.
A number of rendering options are available to ensure that 3D models and graphs (containing a large number of sample points) are rendered efficiently.
You can add a model, open an existing project and save the project.
Import text files, native data files and Touchstone format files.
POSTFEKO supports the export of native file formats. These files can be exported to use in other sessions or when further post-processing is required.
The terms, dataset, slice, trace and 3D result, are used extensively in the documentation. Review the definitions to get a better concept of these definitions.
Display result data on a graph to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations.
A Cartesian surface graph is a flat colour plot with results plotted against two independent axes.
View the simulation data in a 3D view to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations. The 3D view can also be used to verify that the CADFEKO or EDITFEKO model is correct.
The Solver contains a number of frequency domain solution methods, as well as a time domain solution method. By default, all simulation results are obtained in the frequency domain, unless explicitly using the time analysis tool in POSTFEKO to convert the results to the time domain.
View the result types that can be added to a 3D view or a graph.
Add a result to a 3D view or graph using the ribbon.
Add a result to a 3D view or graph using the project browser.
View the quantities and properties that are available for a far field request.
View the quantities and properties that are available for a near field request.
View the quantities and properties that are available for a current request.
View the quantities and properties that are available for an error estimation request.
View the quantities and properties that are available when UTD or RL-GO rays are requested.
View the quantities that are available for voltage, current and waveguide sources as well as FEM modal ports.
View the quantities and properties that are available for loads and networks.
View the settings for S-parameters.
View the quantities and properties that are available for power.
A receiving antenna data described by spherical modes can be added to a valid view.
SAR does not have any special quantities or properties.
A characteristic mode results can be added to a valid view or graph. The mode can either be untracked or tracked by correlating modes between frequency runs.
Imported data or data generated by a script can be added to any view on which the data is valid.
Optimisation data such as optimised parameters, goals, global goals and masks can be viewed on a Cartesian graph after OPTFEKO was used to calculate the results.
With the time analysis tool in POSTFEKO, electromagnetic scattering problems can be analysed in the time domain. The time domain results are obtained by applying an inverse fast Fourier transformation (IFFT) on the frequency domain simulation results.
Use animation to obtain a better understanding of results or export the animation to use in a presentation or report.
POSTFEKO is a useful tool to help analyse and present data in a useful format. It is often required to use the processed results in a report or presentation. To help make it easier to generate these reports, several tools are available in POSTFEKO.
Feko provides a powerful scripting language that allows you to create scripts that control CADFEKO and POSTFEKO.
POSTFEKO has a collection of tools that allow you to quickly validate the model, for example, measure distances, measure angles and finding specific mesh elements.
View the files associated and generated by POSTFEKO.
