Adding a Result from the Project Browser
Add a result to a 3D view or graph using the project browser.
  1. Select the 3D view or graph where you want to add a simulation result.
  2. In the project browser, select the model.
  3. In the model browser, click the Results tab. Use one of the following workflows:
    • Drag a result onto the 3D view or graph.
    • From the right-click context menu and select Add to active window or click Add to new to create a new 3D view or graph.
    Figure 1. Example of adding a far field result from the project browser and selecting a result.
