Viewing the Results
View and post-process the results in POSTFEKO.
The resource requirements (time and memory) for the MLFMM solution are notably smaller than for the full MoM solution. The resource requirements for this example is reduced by using the CFIE formulation on the closed PEC structure of the helicopter. The CFIE required 30% less memory resources and 50% less simulation time for this example when comparing with the default EFIE solution. Some solution times from the .out file are given below. Note that times are dependent on the hardware.
SUMMARY OF REQUIRED TIMES IN SECONDS CPU-time runtime Reading and constructing the geometry 0.710 0.732 Checking the geometry 0.400 0.399 Calcul. of the MLFMM transfer function 10.690 10.783 Fourier transform of MLFMM basis funct. 70.670 71.015 Calcul. of matrix elements 4254.970 4282.781 Calcul. of right-hand side vector 0.010 0.020 Preconditioning system of linear eqns. 48.610 48.881 Solution of the system of linear eqns. 453.320 456.073 ------------ ------------ total times: 4847.260 4878.584 (total times in hours: 1.346 1.355) Peak memory usage during the whole solution: 365.509 MByte
