Visualize Animations
You may visualize your completed results from the Files and Jobs tabs.
Access Web provides you an option to access output result files from the Files and Jobs tab. The Job folders are created with Job ID and hence it becomes easier to navigate and visualizing your results.
Choose your option:
  • From the Files tab, open the Job ID_timestamp in the files list to select an output file that you wish to animate.
  • From the Jobs tab, Open the Job ID folder from the jobs list, select an output file that you wish to animate.
