Set a Job Profile as a Default Profile
Set a profile as a default profile.
When you set a job profile as a default profile, then the default profile will be highlighted when ever you select an application pertaining to that profile.
  1. Click the Jobs tab located in the upper left-hand of the page.
    A list of applications are displayed at the top of the Job Monitoring page.
    Figure 1. List of Applications/Solvers
  2. Double-click an application.
    A job submission form is displayed.
    Figure 2. Saved Job Profile
  3. Select the profile that you want to set as default.
  4. Click Set As Default from the context menu.
    Figure 3. Delete Profile
    The new profile will be set as a default profile.
