View Job Arrays
View the batch job that is submitted to the cluster.
When a batch job is submitted, the monitoring results will look a bit different. Initially, the primary batch job will be displayed in the Job Monitoring. The job identifier assigned to the batch job will have the format jobid[].servername, where the brackets denote a batch job (or job array). In addition, the information displayed in the Job Summary indicates the number of sub-jobs that were submitted, and the number of sub-jobs for each job state.
Note: Job management tasks such as terminating a job, resubmitting a job, or exporting a job will effect all sub-jobs. For example, if a batch job is terminated by clicking Terminate, then all sub-jobs will be terminated.
  1. Click the Jobs tab located in the upper left-hand of the page.
    The job monitoring page is displayed with the list of the jobs that is submitted to a cluster.
    Figure 1. Job Monitoring View
    Note: Job arrays are indicated with "[]" braces with the Job ID and it is also indicated with the icon in the Job ID column.
  2. Click on one of the job array.
    Figure 2. Job Array Summary
    The left panel provides the Filter option to refine the sub jobs that is displayed. This allows you to display the sub jobs monitoring results such as Running, Completed, Failed, and Queued. You can also save the filter option as Favorites.
    Note: Click to go back to the previous page.
    Note: The sub jobs displayed can be refined using the Filter option. You can also save the filter option as Favorites that you have used.
  3. Perform one of the following options:
    • Double-click the sub job name.
    • Right click the sub job and click the View Details from the context menu.
    The sub job of the batch job is displayed.
    Figure 3. Sub Jobs Details
    Tip: You can use the drop-down option located next to the Jobs name and select a particular subjob to view its details.
