Submit a Job by Selecting an Input File
Submit a job by selecting a job input file from your project folder in Windows Explorer.
  1. Open your project folder in Windows Explorer.
  2. Right-click the job input file.
  3. From the context menu, select Process with.
    A list of solvers and saved job profiles along with the server name specific to the file type of the job input file are displayed.
    Right-click context menu
    Figure 1. Solvers and Job Profiles Specific to the Job Input File Type
  4. Select a solver or job profile.
    If additional information is necessary to submit the job, then a job submission form is displayed containing the required solver arguments. Otherwise, the job is submitted.
    Tip: To display all available solver arguments, click All Fields.
  5. Fill in any required solver arguments.
    To reuse the values you entered, click Save as Profile. The next time you choose Process With from the context menu, the saved profile is displayed.
  6. Click Submit.
    The job is submitted and a notification is displayed providing the status of the job.
    Tip: If the file is taking too long to upload or if you provided a wrong input file for the job, then you can cancel the file upload by clicking associated with the job and click Remove from the context menu.
A folder is created in the job output directory. It is named based on the job name and job submission time. Job result files are written to this folder. While the job is running results files are maintained on the remote PAS server. These files can be displayed by viewing the contents of the Running Folder tab. Once the job completes, the job results files are written to the Output tab.
A job is submitted using an input file with the name "file_name" in the format yyyy-mm-dd_hh-mm-ss. The folder that is created is named "file_name_yyyy-mm-dd_hh-mm-ss".
