Location of Application Definitions
Locate the application definition in central server and in your local system.
Access Desktop UI will be updated with any changes in local application definition after removing the time stamp (time_stamp.txt). Notification will also be displayed about the application definition update.
When they are stored in a central repository, then the application definitions are stored on the server host Access Web in the location:
/var/spool/pbsworks/2021.1.2/access/home/data/pas/targets/<PBS_SERVER_HOSTNAME>/repository/applications/
When they are being stored locally, the application definitions are stored at:
C:\Users\%userprofile%\Altair_Access\home\apps\PAS\data\pas\targets\<cluster name>\repository\applications\
