Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
You may visualize the animation results from the Files tab.
The result files are accessible from the Files and
Jobs tab.
The job result files that is saved in
Job ID folder are stored under the
Files tab in the same location where the input files are
placed. Hence, the results files are available from both the tabs to visualize.
Note: Space in the file path is not supported to visualize animation files.
Rename the folder or file name in the File Tab to visualize animation files.
Note: You can download the animation result to your local system and view
it in HyperView Player
On the Files page, open the Job
ID folder.
Tip: You can access the file path as a breadcrumb to select a
particular folder. You may edit the file path manually and use the copy or
paste option to reach a particular folder.
Right-click the result file and then click Open With > Animation TOC.
Figure 1. Animation TOC
The Table of Contents (TOC) for animation
is displayed. Figure 2. Table of Contents for Animation
Optional: Deselect Use Result File and click to select other model file from a remote file
browser location.
Optional: Click Subcase and select the required load case.
Note: Choosing the Subcase is optional. By default, the first entry in the
Subcase list is considered for an animation.
Optional: Click Simulation to select simulation query.
Figure 3. Animation Simulation Query Menu
Select the following in the Simulation Query:
Select Filter
Select Start, End, and Step values.
By default only 100 time steps are available for the view. Click
Refresh link, to view the complete list of Time
Steps.
Note: Setting the Simulation Query is optional. By
default, all the listed simulations in the Simulation
Query is considered for an animation.
Click OK.
Select the required options for the Model and
Result Type, the corresponding
Component Contour is preselected.
Optional: Click , to specify the compression ratio for
the animation file.
Click Animate.
A message to download the HyperView Player is displayed. Figure 4. HyperView Player Download Link
The animation results can be viewed from the HyperView Player application.
Tip: The Back link takes you back to the TOC pop-up
screen for the animation where you can modify the animation
parameters.
Click . The results are downloaded and
displayed in the HyperView Player application.
Optional: Click the hyperlink to download the HyperView Player software. The Altair
HyperWorks web page is displayed with the HyperView player 2019 software to
download.
