Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
View job files from summary tab, input tab, output tab or running folders
tab.
Depending on the state of the job, the job files that you are viewing may be stored
on the remote PAS server.
While a job is running results files are maintained on the remote PAS server. These
files can be displayed by viewing the contents of the Running
Folder. Once the job completes, the job results files are written to
the Output folder in Job Summary.
Click the Jobs tab located in the upper left-hand of the page.
The job monitoring page is displayed with the list of the jobs that is
submitted to a cluster.
Perform one of the following options:
Click the job name from the list.
Select the job name from the list and click the View
Details from the context menu.
Tip: Click Last Submitted job link to view the properties of the
last submitted job that is submitted.
The job summary page is displayed.
From the files list you can select a file to view its content in the
Text, Plot or Image viewers. You can monitor the progress of the job by
viewing the updated contents of the selected file. You can visualize plots
and animations from result files for both running and completed
jobs.
If the selected file of the job is in running state, then the
file will be displayed with the tailing options like Play, Pause, and
Stop.
Note: Based on the job status, the job tab is enabled. If the job
selected is completed, then the Output tab is
enabled. If the job selected is in running state, then the
Running Folder tab is
enabled.
Choose one of the following options:
Click Running Folder tab if you want to view the
files of a running job.
Click Output tab to view the result files of a
completed job.
If you want to open the file in the default application,
double-click the file.
If you want to open the file in the default application, right-click the
file and select Open in the context menu.
If you want to choose an application and to set a default application to
open the file, right-click the file and select Open
With.
Tip: To set a default application to open a file based on the file
extension, then select Always Use this
check-box.
The file will be opened in the application:
You can perform some of the file
operations.
Note: The editing and tailing is only available for
certain kinds of files.
