Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
View the shared application definition and save it as a local application
definition.
The Applications panel lists all the application definitions that you have created
and the shared application definition. You can check the user who has shared the
application definition by clicking .
The application definition must be saved locally to view, edit, clone, share, and
publish.
Click .
Select App Composer.
have created and shared by others. Figure 1. App Composer
Click to view the user who has shared the application
definition.
Note: Delete is the only option that will be available till you save the
application definition locally.
Click the shared application definition to view its parameters in the Compose
panel and to save the application definition to locally.
A notification will be displayed.
Click next to the application definition to view the
complete options of the application definition.
