Delete an Application Definition
Delete unwanted application definition.
The Applications panel lists all the application definitions that you have created. You can delete the unwanted application definitions.
  1. Click .
  2. Select App Composer.
    Figure 1. App Composer
  3. Click next to the application definition that you want to delete.
  4. Click Delete in the context menu.
    The application definition is removed from the list.
