Revoke Access to a User Managed Instance of Budget Manager
Managers can revoke access to an instance of Budget Manager that has been added by an AM Admin.
Budget Manager administrators can add instances of Budget Manager so that the instance can be configured and monitored through Control. A Manager can revoke this access to the instance.
Once the access to the instance is revoked, the user cannot re-add the instance. If the user attempts to re-add the instance, the following message is displayed:
While performing aminstance action: Unable to add Budget Manager instance at <instance name>
  1. Click the Configure tab.
  2. Click Users from the Access Management menu located on the left-hand side of the web page.
  3. Click the name of the user.
    Select User
    Figure 1. Select User
  4. Click Edit.
  5. Click to revoke access to the cluster.
    Revoke Access to a Instance of Budget Manager
    Figure 2. Revoke Access to an Instance of Budget Manager
    Access to the instance is revoked for the user. The following notification is displayed to the user if the user is currently logged into Control:
    Your view is updated to reflect the privilege changes in cluster: INSTANCE
    where INSTANCE is the name of the Allocation Manager instance.
  6. Click Save.
