Setup non-linear separating contact.
For a video tutorial on modeling separating contact, click here.
For more information about separating contact, including validation benchmarks, click
here.
Add a non-linear separating contact analysis branch.
In the Project Tree, click the
Analysis Workbench.
On the Analysis Workbench, click
Add.
Select .
In the Structural analysis popup, select the
Separating contact check box.
In the new Analysis branch, next to the name of the analysis, click .
Identify which contact conditions are allowed to separate.
In the modeling window, select parts of the
model.
Contact conditions for selected parts are listed in the Edit
contact conditions dialog.
Select the
(Action menu) next to the
contact condition and click Edit.
Select the Separating contact condition
type.
Specify a friction coefficient.
A value of 0.0 indicates sliding and 1.0 indicates bonded. Typical
values are between 0.1 and 0.2.
- Optional:
You can select the Apply to all check box to
apply the same edits to other existing analyses of the same type.
