Copy Design Study
Copy an existing design study and update the geometry.
- In the Project Tree, right-click on the desired Study tab.
Select Copy from the context menu.
A new design study tab appears with the same specifications as the copied analysis. - In the Project Tree, right-click on the new Study tab.
Select Update geometry from the context menu.
Any geometry changes made to the CAD design are updated in the SimSolid Cloud project.Note: This method retains the prior analysis results.
