Indoor ASCII Database Format (IDA)
The IDA database-files (Indoor Database ASCII) are in a simple ASCII format.
An IDA file starts with the following header:
* Indoor Database *
* Last changed on: 23. 9.2009  9:41:44 *
Arbitrary number of title or comment lines. The “*” is optional, no special comment character required.
BEGIN_MATERIAL
This keyword marks the beginning of the material data.
* [MATERIAL]  [ID]  [GENERAL]  ["Name of Material"]  [Thickness (in cm)]   [Filled in Display]   [Color: Red]  [Color: Green]  [Color: Blue]
The structure of the material properties belonging to the visualization settings.
* [MATERIAL]  [ID]  [FREQUENCY]  [Frequency (in MHz)]  [Dielectricity (relative)]   [Permeability (relative)]   [Conductivity (in S/m)]  [Transmission Loss Vertical (in dB)]  [Transmission Loss Horizontal (in dB)]  [Reflection Loss (in dB)]  [Diffraction Loss incident min (in dB)]   [Diffraction Loss incident max (in dB)]  [Diffraction Loss diffracted (in dB)]
The structure of the material properties belonging to the electrical settings for each defined frequency.
MATERIAL 1 GENERAL "Material 1" 10.00000 1 0 0 0
Sample Code.
MATERIAL 1 FREQUENCY 2000.000 4.000000 1.000000 0.010000 10.000000 20.000000 9.000000 8.000000 15.000000 5.000000
END_MATERIAL
This keyword marks the end of the material data
BEGIN_WALLS
This keyword marks the beginning of the building data.
1
Total number of walls [integer value].
1 4    33.000,   25.500,    0.000    75.000,   25.500,    0.000    75.000,   57.500,    0.000    33.000,   57.500,    0.000  1 0
Sample Code.
END_WALLS
Contrary to the urban databases, no offset can be defined.
WallMan and ProMan return an error if the number of walls is incorrect when the file is processed.
Following the header, there is one line for each wall or subdivision of the described buildings. At the beginning of the line, an optional comment may be inserted between “*” signs. Unlike in the header, now the “*” signs are compulsory.
If no subdivisions are defined for a certain wall, then the {Number of Subdivisions} parameter is set to zero. If there are subdivisions, the parameter {Number of Subdivisions} defines, how many subdivisions exist for that individual wall.
The subdivisions are then defined exactly like the walls, with only one difference: The {Number of Subdivisions} parameter is omitted (see example below).
The lines for the defined subdivisions must come directly after the corresponding wall.
Each line is structured as follows:
* comment *
{Wall Index Number [integer]}
{Number of corners [integer]}
{x-coordinate of corner # 1 [float]} ,
{y-coordinate of corner # 1 [float]} ,
{z-coordinate of corner # 1 [float]}
{x-coordinate of corner # 2 [float]} ,
{y-coordinate of corner # 2 [float]} ,
{z-coordinate of corner # 2 [float]}
{x-coordinate of corner # n [float]} ,
{y-coordinate of corner # n [float]} ,
{z-coordinate of corner # n [float]}
{Material Index Number [integer]}
{Number of Subdivisions (float)}
At the end of the wall description, the keyword
END_WALLS
marks the end of the file.
This is a sample file containing only one wall with one subdivision:
* Indoor Database *
* Last changed on: 23. 9.2009 10:24:42 *
BEGIN_MATERIAL
* [MATERIAL]  [ID]  [FREQUENCY]  [Frequency (in MHz)]  [Dielectrictity (relative)]   [Permeability (relative)]   [Conductivity (in S/m)]  [Transmission Loss Vertical (in dB)]  [Transmission Loss Horizontal (in dB)]  [Reflection Loss (in dB)]  [Diffraction Loss incident min (in dB)]   [Diffraction Loss incident max (in dB)]  [Diffraction Loss diffracted (in dB)]
MATERIAL 2 GENERAL "Default Furniture" 1.00000 1 0 180 180
MATERIAL 2 FREQUENCY 2000.000 4.000000 1.000000 0.010000 2.000000 20.000000 0.020000 8.000000 15.000000 5.000000
MATERIAL 0 GENERAL "Material 2" 10.00000 1 0 128 0
MATERIAL 0 FREQUENCY 2000.000 4.000000 1.000000 0.010000 10.000000 20.000000 9.000000 8.000000 15.000000 5.000000
END_MATERIAL
BEGIN_SHAPE
1
1   12  124.000,   96.550,   10.050   -32.000,   96.550,   10.050   -32.000,   96.500,   10.050   -32.050,   96.500,   10.050   -32.050,  -12.500,   10.050
-32.000,  -12.500,   10.050   -32.000,  -12.550,   10.050   124.000,  -12.550,   10.050   124.000,  -12.500,   10.050   124.050,  -12.500,   10.050   124.050,   96.500,   10.050   124.000,   96.500,   10.050
END_SHAPE
BEGIN_WALLS
6
7 4   -32.000,  -12.500,    0.000   124.000,  -12.500,    0.000   124.000,   96.500,    0.000   -32.000,   96.500,    0.000  1 1
8 4    11.484,   28.452,    0.000    65.032,   28.452,    0.000    65.032,   64.581,    0.000    11.484,   64.581,    0.000  1
6 4   -32.000,   96.500,    0.000   -32.000,   96.500,   10.000   -32.000,  -12.500,   10.000   -32.000,  -12.500,    0.000  1 0
5 4   -32.000,   96.500,    0.000   -32.000,   96.500,   10.000   124.000,   96.500,   10.000   124.000,   96.500,    0.000  1 2
10 4    83.890,   96.500,    7.476   109.150,   96.500,    7.476   109.150,   96.500,    3.514    83.890,   96.500,    3.514  -1
9 4    20.492,   96.500,    8.467    63.583,   96.500,    8.467    63.583,   96.500,    3.514    20.492,   96.500,    3.514  0
4 4   124.000,   96.500,    0.000   124.000,   96.500,   10.000   124.000,  -12.500,   10.000   124.000,  -12.500,    0.000  1 0
3 4   -32.000,  -12.500,    0.000   -32.000,  -12.500,   10.000   124.000,  -12.500,   10.000   124.000,  -12.500,    0.000  1 0
2 4   -32.000,  -12.500,   10.000   124.000,  -12.500,   10.000   124.000,   96.500,   10.000   -32.000,   96.500,   10.000  1 0
END_WALLS
