AutoCAD® Drawing Databases (DWG / DXF)
AutoCAD® drawing databases in the .dwg and .dxf format can be converted to WinProp building databases. However, not all object categories available in AutoCAD®, are supported by the converter. The following list shows the AutoCAD® object categories supported by the converter module.
For the conversion of AutoCAD® databases to the WinProp format the following object categories are supported:
AutoCAD® Object Categories | Indoor Mode | Urban Mode | Overlay Mode |
Proxy Objects 2) | ![]() |
2D Polyline | - | ![]() |
2D Solid |
3D Box | - | - | - |
3D Face |
3D Mesh | - | - | - |
3D Polyline |
3D Solid | ![]() |
3D Sphere | - | - | - |
3D Surface | - | - | - |
Arc |
Arc aligned text | - | - | - |
Circle |
Donut | - | - | - |
Ellipse |
Hatch |
Line |
MLine | - | - | - |
MText | - | - | - |
MInsertBlock | - | - | - |
PolyFaceMesh |
Polygone |
PolygonMesh | - | - | - |
Polyline |
Text | - | - |
- The AutoCAD® objects must have a closed form, to be converted to urban buildings.
- The current version supports polyline and polygon proxy objects.
- The AutoCAD® objects must have a height value assigned for a correct conversion.
