Run From Command Line
ProMan can be started with additional arguments passed in the command line to load and execute existing projects automatically.
The first required parameter, which has to be passed to the command line is the path and the name of the ProMan project file to be loaded. Afterwards, the prediction mode has to be specified. Further parameters are optional and can be passed in an arbitrary order.
ProMan.exe “C:\SampleProject.net”
Mandatory Parameter | Description |
-p |
Compute wave propagation prediction |
-m |
Compute mobile station prediction using RunMS. |
-n |
Compute network prediction |
-a |
Compute wave propagation, followed by RunMS (if enabled) and network prediction. |
The following parameters can be added optionally:
Optional Parameters | Description |
-fa |
Filter prediction results during computation based on arithmetic mean. |
-d20 |
Limit dynamic in antenna patterns of base stations, for example, to 20 dB. |
-l |
Write computation log file. |
-c |
Close application after the task(s) are completed successfully. |
