User Interface
The ProMan (Propagation) software package is designed to predict path loss accurately between transmitter and receiver. The ProMan (network) software offers network planning modules.
ProMan's graphical user interface window consists of three main parts, the Tree view on the left, the 2D View in the middle and the Legend on the right side. The 3D View can be selected using the Display menu or by clicking on the corresponding toolbar icon. The 3D view replaces the tree view and the 2D view window.
Besides this, ProMan offers four toolbars for quick access to all frequently needed functionalities. The status bar on the bottom of the window gives information about the current mouse position in the 2D view.
Figure 1. ProMan user interface.
- Standard toolbar
- Project toolbar
- Component toolbar
- Status bar
- Utility toolbar
- Edit toolbar
- Tree view
- 2D view
- Legend
Standard Toolbar
New project |
Open project |
Open result |
Open recent file |
Save |
Export Bitmap |
Show version information for ProMan |
Project Toolbar
Edit project parameter |
Edit mobile station parameter |
Set site |
Erase site |
Edit site |
Move site |
Set transmitter |
Enable / disable transmitter |
Erase transmitter |
Edit transmitter |
Move the transmitter. Depending on the selected propagation model, this option may be not available). |
Change transmitter's horizontal orientation |
Define prediction points. Depending on the selected propagation model, this option may be not available. |
Define prediction rectangle (horizontal) |
Prediction trajectories |
Compute propagation for all antennas |
Run network simulation |
Component Toolbar
Add component |
Delete component |
Edit component |
Move component |
Rotate antenna |
Add cable |
Add antenna |
Add transceiver |
Edit Toolbar
Reset zoom window |
Repaint view |
Zoom to prediction area (only in project mode available) |
Zoom to result (only available if result loaded) |
Zoom out |
Zoom in |
Zoom window |
Selection box for display plane in 2D-View |
Save current view area (2D-View) |
Remove selected view area (2D-View) |
Presentation plot |
Threshold color mode |
Edit data |
Change edit-value |
Additional data layers |
3D view |
Settings |
Information |
Utility Toolbar
Display of ray paths |
Single display of rays |
Delete all rays |
Impulse response |
Show prediction planes in a separate dialog |
Show / hide info dialog |
Line plot |
Line plot (from transmitter) |
Probability density function (relative, total area) |
Cumulative density function |
100% - Cumulative density function (total area) |
Show tooltip |
Show distance |
Tree View
Network configuration. |
Databases used in the project. |
Propagation results. |
Network results. |
Human exposure to electromagnetic fields (EMF) results/ |
Electromagnetic compatibility (EMC) results. |
