WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications
ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
Evaluate antenna performance using a virtual-drive test in WinProp. Evaluate different car antenna configurations regarding receiving power and MIMO throughput.
Wireless sensor networks consist of spatially distributed autonomous sensors to cooperatively monitor physical or
environmental conditions (for example, temperature, sound, vibration, pressure, motion or pollutants).
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning
to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output
(MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine
the actual antenna pattern while taking into consideration the local environment.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models
as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks,
ICNIRP and EM compliance.
WinProp's technologies make the tool applicable to the
planing of both urban and indoor radio networks.
Indoor Radio Network Planning
Process 3D building vector data that includes outer and inner walls, subdivisions
like doors and widows. Specify the construction materials and their electrical
properties or import from a database containing industry standard materials. Analyze
the receiving coverage and throughput (data rate) for WiFi planning or an indoor
site for a cellular network.
Urban Scenario Radio Network Planning
Process 3D building vector data superimposed to terrain layer using highly accurate
wave propagation models for macro-cells and micro-cells.
