WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications
ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
Evaluate antenna performance using a virtual-drive test in WinProp. Evaluate different car antenna configurations regarding receiving power and MIMO throughput.
Wireless sensor networks consist of spatially distributed autonomous sensors to cooperatively monitor physical or
environmental conditions (for example, temperature, sound, vibration, pressure, motion or pollutants).
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning
to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output
(MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine
the actual antenna pattern while taking into consideration the local environment.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models
as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks,
ICNIRP and EM compliance.
WinProp can be used to evaluate the in-cabin radio
coverage.
In the world of ubiquitous networking, people want to have continuous connectivity even
when travelling. Using WinProp you can evaluate and plan
different transmitting antennas and leaky feeders to ensure strong in-cabin radio
coverage on trains.
Figure 1. An example of in-cabin radio coverage analysis.
