Create a matching die by offset.
On the ribbon, click the Die Design tab.
Click the Die icon.
Click the Matching Die icon.
Select the die you would like to offset.
To reselect a die, in the guide bar, select
Clear
Selection
, and then select a different die.
Adjust the Offset multiplier.
Right-click and mouse through the check mark to exit, or double-right-click.
Next, export the draw die to Inspire Form to perform a
stamping simulation.
