Create polygonal surfaces that can easily be converted into NURBS surfaces. PolyNURBS combines the ease and simplicity
of polygonal modeling with the precision and flexibility of NURBS, allowing you to quickly create free-form solid
geometry that is smooth and continuous.
This tool has two modes: Push/Pull allows you to move faces, changing the size or shape of your design. Move Feature allows you to translate and rotate a feature (a set of faces such as a hole, pocket, or protrusion). This
tool only works on objects without construction history.
Measure dimensions, analyze curvature, check for continuity and watertightness, analyze the draft, detect undercuts,
and create design iterations on the fly.
Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined
dimensions. You can also insert a general annotation to label the parts of your model.
Quickly modify objects that are not a part of Construction History.
Push/Pull
This tool has two modes: Push/Pull allows you to move faces, changing the size or shape of your design. Move Feature allows you to translate and rotate a feature (a set of faces such as a hole, pocket, or protrusion). This tool only works on objects without construction history.
Untrim
Remove selected edges and extend remaining edges to close the surface.
