Renaming a Table
You can rename a table to provide more meaningful or helpful descriptions for the tables you use in the Prepare Window.
Do one of the following:
Double click on the table's name on the Table List panel or
Click the drop-down arrow beside table you would like to rename and then select Rename Table from the context menu that displays.
Type the new name and hit Enter or click outside the text box.
The name is temporarily highlighted, ready to be modified:
Related Links
