OS-V: 0210 Simply-Supported Thick Square Plate
Test 21OptiStruct is used to investigate the repeated eigenvalues and the effect of ‘secondary’ restrains.
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 1.0m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x=0 and x=10 and y-rotation is fixed along the edge y=0 and y=10.
The material properties are:
Young’s Modulus
200 × 109 N/m2
Poisson’s Ratio
0.3
Density
8000 kg/m3
Modal Analysis Results
The frequency of each targeted mode is normalized with the closed form solution.
f*
Closed form solution
Mode 1 Modes 2 and 3 Mode 4
f* 45.897 Hz f* 109.44 Hz f* 167.89 Hz
HOE 1.013827837 HOE 1.044863043 HOE 1.046793653
LOE 1.005851414 LOE 1.002363027 LOE 1.034589005
Modes 5 and 6 Modes 7 and 8
f* 204.51 Hz f* 256.50 Hz
HOE 1.125821617 HOE 1.094829757
LOE 0.993823531 LOE 1.051061511
Model Files
The model files used in this problem include:
<install_directory>/hwsolvers/demos/optistruct/verification
  • /Test21HOE.fem
  • /Test21LOE.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
