OS-V: 0280 Axisymmetric Elements - Interference Fit Between Two Cylinders
The model examines the contact pressure between two cylinders in case of interference fit of 20 mm.
Figure 1. Model and Loading Description
Benchmark Model
2D axisymmetric elements (CQAXI) elements are used to model 2 cylinders.
- Material Properties
- Young's modulus
- 206 GPa
- Poisson's ratio
- 0
Nonlinear Static Analysis Results
| OptiStruct | NAFEMS | Normalized Target Value | |
| Contact Pressure | 2.35 | 2.27 | 1.035 |
Figure 2. Contact Pressure Between the Cylinders
Model Files
The model file used in this example includes:
<install_directory>/hwsolvers/demos/optistruct/verification/Interference_fit.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
