OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
Test No. T3OptiStruct examines the material temperature at point C, 0.08m from point A and the total simulation time is 32 seconds for
transient heat transfer analysis.
Test No. T4 The model is having zero internal heat generation and OptiStruct examines the temperature at point E for steady state heat transfer analysis.
OS-V: 0110 One Dimensional Transient Heat Transfer Test No. T3OptiStruct examines the material temperature at point C, 0.08m from point A and the total simulation time is 32 seconds for transient heat transfer analysis.
