OS-V: 0110 One Dimensional Transient Heat Transfer
Test No. T3 OptiStruct examines the material temperature at point C, 0.08m from point A and the total simulation time is 32 seconds for transient heat transfer analysis.
Benchmark Model
The 2-noded beam elements, Quad4 elements and Quad8 elements are used to build the model with 5 elements each for the coarse mesh and 10 elements each for the fine mesh. At time t=0, all temperature = zero and at time t>0, at one end temperature is zero and at the other end temperature is 100 sin(πt/40) °C. There is no heat flux perpendicular to the length of the beam.
The material properties are:
Conductivity
35.0 W/m°C
Specific Heat
440.5 J/kg°C
Density
7200 kg/m3
Linear Static Analysis Results
All results are normalized with the target value (36.60°C).
  Material temperature at point C, x=0.08m, time t=32sec (°C) Normalized with the Target Value
Beam Elements:
CBEAM coarse 33.6 1.089285714
CBEAM fine 34.58 1.058415269
Quadrilateral Element:
Quad4 coarse 33.6 1.089285714
Quad8 coarse 35.1 1.042735043
Quad4 fine 34.58 1.058415269
Quad8 fine 35.19 1.040068201
Model Files
The model files used in this problem include:
<install_directory>/hwsolvers/demos/optistruct/verification
  • /T3CbeamC.fem
  • /T3CbeamF.fem
  • /T3Quad4C.fem
  • /T3Quad8C.fem
  • /T3Quad4F.fem
  • /T3Quad8F.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
