Compare HV Version Results
Result comparison HV versions tab ensures that HyperView does not deprecate any result information after post-processing.
- Any combination of results from different data types, simulation and subcases are exported for each HyperView version and compared.
- Any difference would trigger the problem and would be reported.
- Verification of the result file across two versions of HyperView (with the same solver version results).
- Click Messages to view any error messages.
- Click Html Report to generate an HTML report of your session information for any number of files run through the process.
