Compare HG Versions – Template-Session
The Compare HG Versions - Template-Session tab performs time history comparison. From this tab, you can perform the curve super positioning of the current and reference version result files and plot the difference in curves.
  1. Click the Result tab then the Compare HG Versions - Template-Session tab.
  2. Select the current and reference solver version.
  3. Choose between a PowerPoint or HTML report of the result value comparison.
  4. Load the session or template file.
  5. Select an output directory.
  6. Click Apply to extract information from the data file.
  7. Select plot names extracted from the input file.
    Tip:
    • Activate Plot only failed to plot only failed graphs.
    • Activate Visible Only to plot only visible graphs.
  8. Click Apply.
    The Compare result section displays the current file and the corresponding reference file. Click Report to display the diff report detailing the differences between files.
Tip:
  • Click Messages to view any error messages.
  • Click Html Report to generate an HTML report of your session information for any number of files run through the process.
