The Result comparison HG versions tab performs time history comparison. From this
tab, you can perform the curve's super positioning of the current and reference version
result files and plot the differences in curves.
Click the Result tab then the Result
comparison HG versions tab.
Select the current and reference solver
version.
Choose between a PowerPoint or
HTML report of the result value comparison.
Load the data file.
Select an output directory.
Click Apply to extract information from the data
file.
Tip: Click Extract to extract and compare
TRCs in the Current and Reference versions.
Select a subcase from the drop-down menu.
Select an X type from the drop-down menu.
Tip: Activate the Plot only failed checkbox
to only plot failed graphs.
Select any combination of Y Type, Y Request, and Y Component values from the
populated areas.
Click All to select all items listed.
Click Apply to generate TH plots with the selected Y
Type, Y Request, and Y Component.
The Compare result section displays the current file
and the corresponding reference file. Click Report to
display the diff report detailing the differences between files.
Tip:
- Click Messages to view any
error messages.
- Click Html
Report to generate an HTML report of your
session information for any number of files run through the
process.
