HyperStudy allows you to perform Design of Experiments (DOE), optimization, and stochastic studies in a CAE environment. It
allows you to study the different aspects of a design under various conditions, including non-linear behaviors. It
can be applied in the multi-disciplinary optimization of a design combining different analysis types.
Response Variables can be removed from the study by
deleting them from the wizard.
To delete a Response Variable, select the desired RV from the list and click
the Delete button.
Tip: Responses can also be deleted outside the wizard by
right-clicking on the RV in the Project Browser and
choosing Deactivate > Selected Objects(s).
Such RVs will be highlighted in ‘red’ in the wizard and
will not be considered for the optimization study.
