Materials
Use the tool to view, add, and edit the material properties that are used for NLFE bodies.
Create and Edit Materials
Hyper Elastic Materials Overview
For hyper elastic materials, different constitutive material models are supported, such as: Neo-Hookean (both compressible and incompressible), Mooney-Rivlin, and Yeoh models that are used to model a hyper elastic NLFE Body.
Hyper elastic materials can undergo large deformations with a non-linear stress strain relationship.
The constitutive models for hyper elastic materials are characterized using the strain energy density function.
Type | Equation | Description |
Neo-Hookean Compressible | U - Strain Energy density function μ - Shear modulus - rx, ry, and rz are the gradients of NLFE grids , is called the 2nd Lame's constant, v is the Poisson's ratio
Neo-Hookean Incompressible | , bulk modulus |
Mooney-Rivlin | μ01 and μ10 are material constants
, where C is the Cauchy-Green deformation tensor
are the gradient vectors |
Yeoh | C10, C20, and C30 are material constants |
The material constants for these models have to be derived through testing, such as: uniaxial, bending, and shear tests.
